Home › Forum › Ask A Member › QD10 Float
  • #2231
      Has anyone modified a newer float to use on a QD10? Then screw the hinge onto that.
      Motor was flooding like crazy. Opened her up, and found the float was so swelled, it was catching on the float bowl housing.
      I see vintage outboard has the bowl gaskets, but that is about it.
      #21778
      Casey Lynn
        I just did that on an RD (35hp) that had the old cork float.
        Used one of the new floats out of a 40-70hp and shaved it down to fit. Took about two minutes
        #21784
          Great thanks.
          Are needles and seats still available for the early QD?
          The needles on these have the groove cut into them that the float arm locks in.
          I suppose if they cannot be found, you could modify a newer needle and seat by cutting the groove. Wonder if the groove for the spring on the newer needles lines up?
          #21798
          beerman57
            I think the float is about the only thing not available. I did a QD11 that had been sitting for probably 25-30 years. Seaway even had the coils, but they were expensive.
            #21811
            Casey Lynn
              Think there is still a kit for that engine that includes the parts you are looking for
              #21842
                I emailed seaway, so will see.
                I have a box of floats, but none have the width that the QD10 has. When I install the float clip on them, they don’t come level with the casting when inverted. They are short as they are not wide enough. Maybe Ill make one from scratch.
