Home › Forum › Ask A Member › QD 24 lower block corrosion
  • #277713
    GARY
      Is there any reason for significant corrosion where the O ring on the lower crankshaft bearing seats (groove in crankcase) other than a leaky base gasket?
      #277718
        Water in crankcase (is the bearing rusted).  Water coming up from drive shaft isolation tube (are the parts present on top of water pump)
        #277721
        GARY
          Thanks Frank,bearing is fine the corrosion was just in the o ring groove.Before I re-install the powerhead I was going to change impeller so I’ll check for leak potential there.
          #277747
            I’m not sure I understand just where this corrosion is, perhaps you can post a picture…
            #277765
            GARY
              The roller bearing on the bottom of crankshaft has an O ring around it that fits in a groove in the crankcase.The corrosion was in that groove.The block has been reassembled  so no picture possible. I replaced impeller and nothing in that area was missing or needing to be replaced.No signs of water in cylinders or crankcase.
              #277768
                wonder if it was some sort of casting defect
