Home › Forum › Ask A Member › QD-20 compression.
  • #267591
    elgin2
      What is the exceptable compression for a Johnson QD-20 10 h.p.? I picked one up that has 60-65 lbs. compression. Thanx in advance.
      #267594
        My QD-20 runs great with about 82 psi in both cylinders.    Yours might be a little low due to stuck rings or maybe a blown head gasket.
        1982 Evinrude 25hp
        #267596
          just run it for a while with some  engine cleaner product .   some like SEAFOAM  some don’t like it  but give it a try. Mercury  and Evinrude have their brand
          retest after  a few hours … if it runs good maybe your  meter was off …. try another  one and compare
          • This reply was modified 4 years ago by JACQUES.
          #267597
            I’m not quite sure what year a QD20 is, but you may also want to check for sloppy wrist pin bushings as well.
            #267600
            elgin2
              Thanx gentlemen. I won’t give up on it then.
              #267606
                1959 Johnson QD-20 10hp
                #267613
                  Compression numbers would be good closer to 100 PSI.
                  Your ’59 QD-20 should look like this one, with a single chrome ring on top of the hood.
                  DSC01208
                  • This reply was modified 4 years ago by Mumbles.
                  #267619
                  elgin2
                    That’s it. Got it at a auction for $2.
                    #267620
                      ok we  want a picture or 2 or 3 ….!
                      #267624
                      elgin2
                        It doesn`t look as nice as the one above. Let me see if i can figure out how to post pictures.
