Home › Forum › Ask A Member › QD 11 carb question
  • #3736
    davidk
      The carb on the QD 11 has a hose, called the "carburetor manifold hose." It’s plugged at the end…. with the "carburetor manifold plug," of course. What does this hose do?
      david-bartlett
        DAVID,
        I do not have your answer, but the Johnson Service manual calls it a Leaf Valve Silencer Tube.
        Someone will know.
        #32683
          http://boatinfo.no/lib/johnson/manuals/ … hnson.html
          if you need the whole book….but as illustrated it does not describe the hose much…
          Joining AOMCI has priviledges šŸ™‚
          #32710
            It isĀ supposed to make it idle more quietly. Replaced on later models with an air intake silencer.
            I get the same effect by just shutting off my hearing aid . . . . šŸ˜€
            #32720
            melugin
              Thanks, that item has puzzled me.
              #32733
              davidk
                Thanks for the info!
