Home › Forum › Ask A Member › Propeller MB5259 info
- This topic has 7 replies, 3 voices, and was last updated 8 months, 2 weeks ago by
JOSEPH BRINCAT.
February 13, 2026 at 6:12 pm #304581
Hello all, can we identify this little aluminum prop MB5259 6 -5/8″ diam two blade. It came with a Merc KD 3 but obviously is not the correct prop for that motor… it does not fit. I scanned the Michigan Wheel Cat… not there , not even a Michigan wheel number format. It must be for a small motor 2 to 3 HP . Any ideas?
Thanks,
February 14, 2026 at 8:44 pm #304601What defines “obviously does not fit”? I have very little knowledge about mercs but I’m sure that would help narrow it down. 6 and 5/8″ diameter does not seem too far off for diameter but that could just be me.
February 15, 2026 at 10:02 am #304611I was just hoping that someone would recognize the model number MB5259. It defiantly does not fit the KD3 , the hub is way too short and the diameter is an inch too small.
February 15, 2026 at 10:02 pm #304693February 17, 2026 at 5:11 pm #304734Oh yeah, that is where I heard that number. I could check my air Cooled water witch number if that is of any help.
February 18, 2026 at 9:53 am #304749Yes, I think that the “MB” / Waterwitch connection may help. I checked my little 3/4 hp Waterwitch and no match… maybe a larger motor would use that prop.
February 18, 2026 at 10:10 pm #304802February 18, 2026 at 11:14 pm #304815Thanks Tubs , looks similar but the MB5259 is the opposite rotation. not sure if you call it RH or LH , but looking from the aft end its LH rotation…. CCW
