Home › Forum › Ask A Member › propeller I.D.
  • #1482
    hydrojet
      I have a 3 blade bronze propeller with markings of Michigan SX 16502, _mc 26 8" x ? pitch. I couldn’t find anything in my Michigan props fr0m
      1944 to 60. Any info would be appreciated. Thanks in advance
      #15903
      weedlessdrive
        I can’t find anything in my catalog that runs from late 20’s to 1942. Most of the early codes are one letter followed by three numbers.
        #15905
        r-c
          Those numbers appear to be a re-work service number. Many of the service stations use their own code, usually all numbers when they repair a prop. A lot of the early OMC props have the part number and diameter and pitch cast at the inner hub. You have to scrape the crap away to see it with a good eye and flash light.
          #15926
          Indian Group Leader
            The closest thing I have found is AMC260 which is a 3 blade bronze prop that is 8.5" x 10 pitch and fits the following:
            1950-1957 Johnson/Evinrude 10HP
            1950-1960 Johnson/Evinrude 14HP, 15HP, and 18HP
            I don’t know if that helps, but I tried.
            Tom
            #15938
            weedlessdrive
              Do you have a picture of it maybe and measure the shaft diameter? That might help narrow it down.
              #15997
              hydrojet
                Shaft dia. is 5/8 I found info onamc26 for merc mark 10. I will try pics. Thanks. I thought 16502 was interesting 502 ? Most small merc are 7/16 1/2 "
