Home › Forum › Ask A Member › Propeller hub replacement
- This topic has 8 replies, 5 voices, and was last updated 5 months, 4 weeks ago by
ED.
April 23, 2025 at 6:29 pm #295800
All,
I have a 1960 Evinrude 18hp Model number 15032 with a slipped hub. I have spoken to 3 prop shops near me and none of them will replace this hub. Left with no other option I decided to attempt this on my own. I have ordered the replacement hub (VS-10) from HMS hubs and am trying to install it. I have followed their directions and I’m unable to get the hub pressed in. According to their directions I have cut the corner of the bub back 3/16″ at a 45-degree angle, soaked the hub in 180-degree water and then lubed it with a 50/50 mixture of dish soap and rubbing alcohol. When I tried to press it in it appeared that the hub was starting to crack. I did confirm with them before attempting to replace it that I did not need a funnel to complete this installation. I know that I can “pin” the hub but I’m all about doing the job right. I have 2 hubs to replace and figured that I would reach out and see if there are any tricks that you could share with me or if there was a specific propeller shop that someone would recommend that I could ship my propellers too. I am using a 60 ton press to press the hub in.
April 24, 2025 at 11:55 am #295807For the cost of the hub and all the trouble installing it, you may want to consider a new prop. Solas (an imported prop) makes excellent aluminum propellers, at reasonable prices. I have bought several for a variety of motors over the last several years. Example: An 11 inch pitch prop for your motor is Solas #2111-093-11P . You can buy them online at several places. Wholesalemarine.com has that one for $73, and as a 1st time buyer there, they usually take 10% off that. For some unknown reason, the photos of the prop online show it as a “through the prop exhaust” type, but it isn’t. I occasionally pin a spun prop, but just to use as a spare.
April 25, 2025 at 6:57 pm #295858I have heard from a member who has re-hubbed a lot of props that cracking the old aluminum OMC ones while installing no hub is not a rarity.
April 26, 2025 at 6:51 am #295872Dave,
Thank you for the information. I might just order the propeller you mentioned. I think that I will also try to get them pressed in as well since I like the challenge. The motor is used at a remote cabin so I won’t be able to test the ones that I press in till I get there and not having a spare propeller that works is not an option for me. Thanks again
Jon
May 13, 2026 at 1:45 pm #318644heat the prop and the hub up that should help it some and if it crack it cracks
May 13, 2026 at 3:05 pm #318652All,
JT here is my two cents on this subject. The cost of replacements propellers sometimes is reasonable but sometimes the propeller you purchase is also spun. I decided to try something to push the new insert in and the old one out. I bought a ball joint replacement kit. Clamped it in my vice and pushed out the old and slipped in the new, good as new! The kit came with a guide sleeve that keeps the new insert from bulging. I used the same 50/50 mix that was recommend as you did. I was surprised at how good it worked! I will try to post some pictures. These pictures are from a 35hp OMC. Pictures not posting, I tried twice!
dale
May 13, 2026 at 3:08 pm #318655May 13, 2026 at 3:14 pm #318660All,
dale
One more time!
May 13, 2026 at 3:37 pm #318664check with Indy Prop Shop They have ad in Antique Outboarder I have used them without any problem. Ed Elliott
