Home › Forum › Ask A Member › Prop suggestion for running twins
- This topic has 16 replies, 7 voices, and was last updated 11 years, 7 months ago by
chinewalker.
March 17, 2015 at 2:32 am #942
Howdy,
I am in the process of rebuilding a pair of 1957 Evinrude 35 HP Electric Start Big Twins.
Any suggestions on what props to use?
They are going to power a 1957 Crestliner Voyager Hardtop.
Thanks,
JohnMarch 17, 2015 at 5:54 am #12154Cool project.
More specific info about total weight, length, number of passengers would be helpful. My data shows 1956 Voyager Hardtop is 18′ and 510 #dry and rated for 60 hp. Transom width 54". Any extra floor weight? Fishing boxes and gear? etc.My Alumacraft Super CS is 15′, 400# dry, Transom width 58" with twin 57 35hp Javelins. So your boat is 3′ longer, about 100# heavier with narrower transom (and slightly wider amidships). I use twin AJC 465 (10 diam X 16 1/2 pitch 2 blade brass). I get 35 MPH with two people and about the same with 4-5 people. About 30 # of anchor, tools, and life jackets. Humongous torque and instant hole shot with twin blades and 70hp. Mid speed acceleration from fuel saving cruise throttle to WOT is a neck whipping thrill. Great fun!
Assuming both your 35’s are fairly low hour (about 120-130psi) and properly tuned I am guessing you could safely run twin AJC 460’s (10X15) or AJC 461’s (10X 15 1/2). AJC 465’s may be a little too much for your larger boat and heavier load.
March 17, 2015 at 5:57 am #12155I Tried to add a photo to my post from photobucket by adding the IMG code from photobucket same way as I did with the old board, but it won’t post the photo. What am I doing wrong?
March 17, 2015 at 5:58 am #12156March 17, 2015 at 6:00 am #12157That worked. So photo has to be added to a separate post???
March 17, 2015 at 6:01 am #12158March 17, 2015 at 6:11 am #12159I tried to add the photo to my original post 5 times and it didn’t work. Then it did work on the short post above. Then I tried to post this same explanation with no photo at all and that didn’t work either. Is there some kind of computer glitch going on here?? I don’t understand computers.
March 17, 2015 at 10:31 am #12162Lloyd that’s a beautiful boat! That has to be my favorite Alumacraft, with twin Javelins it’s even better. I’ll have to talk you out of a ride some time.
March 17, 2015 at 3:42 pm #12181quote Lloyd:I tried to add the photo to my original post 5 times and it didn’t work. Then it did work on the short post above. Then I tried to post this same explanation with no photo at all and that didn’t work either. Is there some kind of computer glitch going on here?? I don’t understand computers.Lloyd, there’s no reason why it shouldn’t work to have a picture and post at the same time. The forum might not allow you to post so quickly, or there could be a couple other things going on.
If you have issues, PM me and I’ll try to walk you through it.
March 17, 2015 at 6:01 pm #12189Thanks. I will just take it slow and try to get used to it. Just gotta remember to copy my posts, so I don’t loose them in hyperspace. Sorry about my confusion and multiple posts.
