Home › Forum › Ask A Member › Prop storage dilemma
  • #7077
    opposedtwin
      I have waaaay too many props, but I hate to get rid of them out of fear I may need one some day. Until I have my collection somewhat more complete, I’ll have to hang onto them.
      Until that day, I need to find an efficient way to store them. How do you guys store your props if they’re not on a motor?
      Thoughts? Suggestions? Pictures?
      Thanks!
      #58059
        use a heavy base. add a threaded rod to the center slide the props on the rod works great. I used a brake drum. now have 6ft rack taking up no space.
        #58075
          I stack them in totes.
          #58086
          mr-asa
            I’ve seen ’em strung up on lines and hung between rafters in people’s shops.
            #58093
              I solved my prop storage problem……. gave a whole tub
              of them away at Tomahawk….. a lot of them were
              Chrysler, or which I had nothing to put them on!
              fisherman6
                I hope I can find someone giving away Chrysler props at Tomahawk. I have a 9.6 Sea King that has kind of a beat up prop on it. It needs a few other things too, but a prop is one.
                I have seen them on threaded rod posts and strings lots of times. I have them in a tote, but I don’t have that many of them.
                -Ben
                OldJohnnyRude on YouTube
                #58095
                opposedtwin
                  quote Buccaneer:
                  Hey buccaneer! I will definitely be giving away many this year at tomahawk. Many of them I simply can’t identify so there’s no use hanging onto them.
                  #58103
                    Use drywall screws to hang them on.
                    #58222
                      We used iron spikes driven into the logs of the garage at Houghton Lake – 84 of them, as I recall. Here in Florida I used 1/2" dowling set into the studs. Our termites love them . . . :mrgreen:
                      #58315
                      retiredoz
                        Ol rusted Merc driveshafts (the ones with the pinion gear attached) work just fine too. Stack them and put them where you have to trip over them.
