Home › Forum › Ask A Member › Prop shaft seal
  • #5451
    4stroke
      Should a prop shaft seal be single or double lip? Trying to come up with something for my Homelite 55hp.
      THX,
      Dick
      #45447
        What has proved most effective is using two thinner seals back to back. The inner seal keeps the oil in, while the outside seal keeps the water out.
        #45461
        DAN ANDERSON
          If you use back to back seals it’s nice to have a small gap to put some grease in between the two seals. I use OMC/BRP Triple Guard. If the seals do their job the lips need some form of lubrication.
          Dan in TN
