Home › Forum › Ask A Member › Prop seal orientation on 1969 Mercury 35 hp
  • #294699
    ChrisAF
      Hi Everyone,
      I’ve search to the end of the internet and I can’t seem to find the answer to this question, so I’m turning to you,  the experts!
      What is the proper orientation of this prop seal? Part number 26-90562. Please see pictures labeled “Side 1” and “Side 2” for clarity. The old seal was oriented with “Side 2” facing aft (water side).
      Every thing I’ve found on this topic is in reference to an outboard with 2 prop seals, but I cannot find definitive guidance on the orientation of a single prop seal.
      Thanks in advance for your help!
      #294707
      CHUCK
        I believe that I’ve heard it said that;  generally speaking,  the “open” side of the seal….with the spring….typically faces the fluid you want to contain.
        #294717
        ChrisAF
          That’s the general guidance I keep seeing. I’ll go with that. Thanks!
