Home › Forum › Ask A Member › Prop Repair/Replacement
  • #3819
    morelor
      Hello,
      I have a 25hp 1969 Johnson (25R69D) that I believe has a spun prop. Is it worth trying to have the prop repaired or would I be better off replacing the prop? If replacement is the better option, does anyone have any recommendations for a replacement? Would it be wise to stick with a factory prop or is an aftermarket part the better option?
      Thanks in advance for the help!
      #33271
      collectorinspector
        Spun hub can be replaced if you wish.
        I would consider the overall condition of the item in deciding a hub pressed in.
        If the prop is well worn and worn well original………consider a replacement.
        A new prop makes the boat so much better!!!!!!
        Should be easy to get a new one.
        If you are happy with the original dia x pitch do not change the replacement prop for something with different measurements.
        Cheers
        BnC
        #33308
        morelor
          Thanks for the info collectorinspector. I think that will go ahead just buy a new prop. These are the two props that I was looking at that have the same dia x pitch as my current prop:
          Michigan Match
          http://www.boatersland.com/mwc012011.ht … oCAxnw_wcB
          EVINRUDE/JOHNSON
          http://www.ebay.com/itm/161990112208?_t … EBIDX%3AIT
          Are there any disadvantages or advantages to buying an aftermarket prop like the Michigan Match vs a factory prop? I guess my main concern is quality.
