Home › Forum › Ask A Member › Problem setting new points gap evinrude 1966 5hp
  • #328771
    So I bought this motor a few months ago and have been working on several issues to see if it will start. Compression check is approximately 70 psi both cylinders. I have rebuilt the carb and put new impeller in the lower unit. So I did have spark both cylinders but never could get it to start. So I removed magneto plate and tried to put a new set of BRP points on and re-assembled plate to the motor. Could never get points to open when cam top indicator hits the point cam foot. So I removed everything with the magneto plate still attached and re-installed points with no luck. So put the old points back and now I can set the gap to .020”. However, I still cannot get to start so I am thinking the spark may be too weak. I can only check with one of those clear Harbor Freight spark checkers. So is there some trick to get the new points to open? I tried adjusting the hold down plate and screw cam and no luck. Thx
    #328779
      did you physically compare the two sets because some (New)  points have been known to be flaky.   if they are the same identical size ( rub arm lenght wise )  no reason not to open.
      post some pics  side by side.
      TOP on the cam means top side  not TDC !     Points  rub arm  needs to be set on the highest point of the cam thenadjusted  to .020  with the adjustment elleptical screw.
      if you  have good sparks with the  old points work with those…see if the  engine will kick over with a spoonfull of fuel inserted in the plug holes…. or easier…. a blast of fuel mix in the carb face……  report back results
      http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
      #328784
        Yes indeed.  There was even a bad batch of new OEM points from BRP like this as well.
        #328848
          There are other issues besides the ignition that can keep a motor from starting. If your getting a spark with your tester you may need to look elsewhere.
          #328858
            Yes indeed.  You have reinstalled the original points and have spark?  Perhaps you reversed the plug wires.  Try priming the cylinders with a little fresh fuel/oil mix to see if it will fire briefly…
            #328865
            JOSEPH BRINCAT
              Compare the steel base plates of the point set, I seem to recall some discussion about the hole that the eccentric adjusting screw fits into not being in the correct position so as to allow the breaker arm to move close in to the cam , thus allowing the points to open.  If that is the issue, just use a small round file to adjust the hole.
