Home › Forum › Ask A Member › Problem converting Johnson1955 25 hp RD-17S to RDE-17(mounting starter)
  • #189505
    outboardnut
      Let me start out saying that-
      1.The carb has been rebuilt and is from a RD-17S. I don’t have a RDE-17 carb to compare with. All I have are parts lists from both.
      2. This motor will be used with a tiller-so I don’t care about having electric choke.
      3.The upper carb body(#57) on both RD-17S to RDE-17 have the same part number.
      4.I was able to obtain a starter (MAK 4033 4K),correct starter bracket and flywheel.
      The problem I am having is-
      When I try to mount the starter .The starter bracket hits #55 lever.(see RD-17S parts list).I noticed on the RDE-17 parts list that there is no lever. My plan is to find the type of throttle shaft(#47) (376239) that is used on a RDE-17 and eliminate the lever and replace with washer and cotter pin.
      But if I do that the rear butterfly(throttle valve) with not be able to be activated when I pull on the choke knob.
      Also
      #68 (choke rod)is different on each carb. Would I have replace that also??
      Also
      Any advice on removing the two screws that hold throttle valve(#52) to the throttle shaft?? I did this once a long time ago and I remember having some kind of problem
      Also
      Since I don’t have a RDE-17 carb. A picture of the area where #55 is would be appreciated along with thoughts and advice.
      Thanks Al 630-624-8382
      1955-RD-17S-carb-pic
      1955-RDE-17-carb-pic
      1955-RD-17S-carb-list
      #189519
      outboardnut
        1955-RDE-17-carb-list-2
        #189526
          Can you modify the bracket ? just a thought.
          #189528
          outboardnut
            If I did that I think I would compromise the starter housing
            • This reply was modified 6 years, 10 months ago by outboardnut.
            #189533
              Not sure if this will help, but it’s my RDE-17
              DSCN6904
              DSCN6905
              DSCN7116
              DSCN7118
              outboardnut
                Thanks Buc Thats what I wanted to see
                Buc Please check your private messages
                #189544
                outboardnut
                  this is what my carb looks like from RD-17S
                  20191217_180452
                  #189552
                    Looks like your carb gives you a fast idle when you pull the choke out.
                    Perhaps you can find the correct carb parts or do some kind of
                    modification?
                      Looks like they didn’t figure an electric start motor would be rope started often enough to need a throttle kicker.
                      #189563
                      outboardnut
                        spring-side
