Home › Forum › Ask A Member › Primer bulb location
- This topic has 19 replies, 13 voices, and was last updated 9 years, 12 months ago by
bob-d.
November 6, 2016 at 4:37 pm #5642
Going to run about a 11′ single gas line for a 1971 Merc 9.8HP to help the weight distribution on a 6 gallon tank in an Alumacraft.
Should the primer bulb be mounted near the tank, or closer to the engine, or it doesn’t matter?
Thanks.November 6, 2016 at 4:52 pm #47074The primer bulb on every hose i’ve had is located a foot or so from the tank. I recall i read in the fuel system part of a manual that the bulb should be located near the tank. So yes it does matter.
Robbie RobertsonNovember 6, 2016 at 4:59 pm #47075I think it will still work and be a lot more convenient if put near the motor end.
November 6, 2016 at 5:07 pm #47076Actually it work anywhere you put it. If close to the tank, it will take fewer squeezes to get fuel to it if starting with an empty bulb & hose. They are a lousy air pump. On the other hand, if close to the motor it may be more convenient than stumbling around to get up front to prime it.
Short story: It is up to you, and your situation.
November 6, 2016 at 5:17 pm #47078Thanks everyone for the info.
Since there are no strange fluid dynamics factors which would cause running or starting problems, I am opting to put it closer to the the motor for the convience factor.November 6, 2016 at 10:31 pm #47085Holding the primer bulb with the arrow facing up [vertical] while squeezing will pull the fuel much faster. This is because of the check valves in the primer bulb. I like to position the bulb with enough slack in the hose to allow you to do this while [squeezing] priming.
November 7, 2016 at 12:57 am #47092If mounted on a high shelf in the bow, the tank could be higher than the motor. If that is the case, then it will take very little effort to pump fuel to the motor. Once primed, it is almost a gravity feed. . . ๐
November 7, 2016 at 1:58 am #47099quote Jerry Ahrens:Holding the primer bulb with the arrow facing up [vertical] while squeezing will pull the fuel much faster. This is because of the check valves in the primer bulb. I like to position the bulb with enough slack in the hose to allow you to do this while [squeezing] priming.I concur with what Jerry has said. The easier for the check valve to work the better. If you have a hose that seems to be slow to prime, try this trick. These check valves are not of the highest quality.
Steve
November 7, 2016 at 6:35 pm #47123The valves are not spring loaded – by holding the bulb with the arrow pointing up lets gravity aid in the sealing. . . ๐
November 7, 2016 at 7:32 pm #47128you can always install two ๐ก .. one at each end of the boat ๐
Joining AOMCI has priviledges ๐
