Home › Forum › Ask A Member › Pressure tank leaking at primer button
- This topic has 9 replies, 5 voices, and was last updated 11 years, 4 months ago by
frankr.
June 20, 2015 at 9:21 pm #1805
My pressure tank has started leaking at the primer button. It’s the older style tank with the big aluminum button. What are the part numbers to fix this?
Thanks,
Steve.
June 20, 2015 at 9:39 pm #18517You need to take it apart and inspect it. Could be a holed diaphragm or a corroded end on the push rod or distorted supports or just a loose nut. Or all of the above.
June 20, 2015 at 10:16 pm #18520June 21, 2015 at 4:53 am #18550from what I got into with my tank would suggest getting the rebuild kit and go through the whole thing. the problem is probably the diaphragm but better off to do the whole thing and be set for many years.
Doug
turned off?June 21, 2015 at 11:10 am #18556quote ddwilson:from what I got into with my tank would suggest getting the rebuild kit and go through the whole thing. the problem is probably the diaphragm but better off to do the whole thing and be set for many years.I’ll second that. While you have it apart you might as well do a complete cleaning and rebuild. Unless you have replaced the fuel tank gasket, it will likely crumble when you remove the top. Also, you can refinish or replace the float, and give the fuel tank foot valve assembly a good cleaning.
Improvise-Adapt-Overcome
June 21, 2015 at 11:35 am #18557Thanks for the help guys. I did rebuild the thing a year ago. I actually had the thing apart yesterday morning to check the fuel screen and everything looked to be in good order. Except that when I put it on the motor, it started leaking from the primer button. Hopefully it is something simple.
June 21, 2015 at 1:42 pm #18563Is there a part number for the rebuild kit?
June 21, 2015 at 10:25 pm #18619A tidbit of info on that system: The knob is supposed to rotate freely on the push rod. If it is corroded and stuck, pushing on it tends to unscrew the rod from the nut on the bottom, resulting in a leak. You might try just turning it back in. You might get lucky. But of course the real solution is to free up and lubricate the knob so it doesn’t turn the rod.
June 21, 2015 at 10:43 pm #18623Thanks, Frank. The knob rotated freely. The nut was tight. However, there was some gunk on the push rod, so perhaps that opened up the diaphragm a bit. I’ve got another on order.
June 22, 2015 at 2:43 am #18651The end on the push rod where it sits on the upper diaphragm support has to be square and true to form a seal between the rod and diaphragm support. A dab of fuel proof gasket sealer there doesn’t hurt either. If any of that leaks, gas goes up through the whole assembly, following the threaded portion of the push rod.
