Home › Forum › Ask A Member › power hwad swap
  • #6425
    marty-a
      Will a 1977 85 hp Evinrude power head bolt up to a 1983 115 hp mid section. looking to update the trim system from the outside pump to the internal system. Marty
      #53595
      DAN ANDERSON
        It is not a bolt up. The bolt pattern on the two powerheads is slightly different as evident by the different base gaskets, but it has been done. It require a bit of work. Filling the existing holes in the powerhead and re-drilling using a late gasket #342513 for a template.
        The late style trim is sure worth it.
        Dan in TN
        #53596
        DAN ANDERSON
          Marty; I might have forgotten something more important than bolt pattern. Does your ’77 motor have a multi spline driveshaft or a 4 flute shaft at the top? Your gearcase won’t fit the newer midsection and of course a newer gearcase won’t fit your old powerhead if it has a 4 flute crank. Hope that makes sense. ’77 was the change over year for the 140hp V-4 & 25" 85 & 115hp motors to the new midsection with new trim. It was 1978 before the 20" 85 & 115 went the new style parts.
          Dan in TN
          #53654
          marty-a
            Thanks Dan, not sure about the drive shaft as it was serviced just prior to my purchase. Was having problem with t&t leaking and found 3 stripped fittings, repaired and no leaks but can’t purge air out of system. Sweet running power head though.
