Home › Forum › Ask A Member › Power head assembly
  • #7856
    clemg
      Looking for suggestions for lubing piston’s rist pin
      Crank for assembly.
      #62745
      fisherman6
        Probably lots of suggestions out there. I’d use this
        https://m.advanceautoparts.com/p/permat … lsrc=aw.ds
        -Ben
        OldJohnnyRude on YouTube
        #62747
        DAN ANDERSON
          I prefer Mercury assembly lube for needle bearings. It can be hard to find as I think they may have dis-continued it for awhile? I found out my local Merc dealer could get it & stocked up. I like it better than OMC (vasoline) as it just melts in hot weather & doesn’t hold the bearings as well. If you are just talking about general lubrication for assembly like pistons, rings, etc. I use 50/1 oil. Just like I mix with the gas. I don’t care for anything in the engine other than that. Just my opinion!
          Dan in TN
          #62757
            Coat everything with lots of TCW III as the fuel mix will help to maintain the protective coating.
