Home › Forum › Ask A Member › Possibly my next project
  • #2158
    wyo307
      Hello all,
      I was looking through the pictures to an upcoming auction and spotted this. From what I can tell it looks to be an early 50’s 25 hp Johnson. Can anyone help me identify it? Looks to be set up for a steering wheel not a tiller. If the price is right I might pick it up. It also looks like there is another smaller engine next to it but i’m not familiar with them enough to identify it by just the lower unit. Any help would be appreciated.
      #21254
        You are correct, it is an early 50s Johnson 25hp. Looks like the old girl has been setting there for an awful long time, you would want to have a much closer look before shelling out money for it.
        #21255
        Leon
          Yep, that is an early 50’s RD. That looks like a good find Under all that grease, you’ll likely find a real gem. It looks like its been oiled good all its life
          I believe the other motor is an old Scott.
          #21260
            Pretty sure it is a 1953. The other motor I cannot identify sorry!
            #21263
              http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
              all the info you need minus some small variants
              try to find the model number and get your parts listing of MARINE.COM
              #21272
              wyo307
                quote 1946Zephyr:
                I think you are right about the other motor. When you said scott i started researching and it looks a lot like a 1946 Scott-Atwood which would mean it is a 3.6 hp being that is the only thing they made that year. Now that I look at it closely it is a rather unique lower unit. I think that I would rather have that over the big johnson just for ease of transport.
                #21273
                wiscoboater
                  If you can grab that baby for less then $100 and it turns over I would jump on it. But then…I have been burnt before on these old gems. That one looks like it would clean up really nice tho, decals look nice, prop looks good. I’d take the gamble..again, only if it turns over.
                  #21274
                  david-bartlett
                    The RD looks to be missing it’s tiller. Pretty easy to come by if it is good for good. I have a 54 and it is a blast to run. A "little" noisy by todays standards but so what! The Cool factor makes up for it.
                    #21300
                    thumper
                      the other motor is definitely an older Scott. Too bad you didn’t get the power head in the pic
                      #21325
                      Casey Lynn
                        Don’t be late on buying that RD! Those are great engines and it looks to be in pretty decent shape under that dust.
                        They are excellent runners and a lot of fun! If it has original cracked coils that will be even better as there would be no way some idiot had a chance to run it on 50:1 before you buy it.
