Home › Forum › Ask A Member › Poppet valve carb
  • #926
    mercuryman
      I am working on a Elto Pal that won’t stay running. Anyone have the spec sheet for Poppet valve carbs. Has to do with valve lift and spring pressure.
      Thanks Birney
      #11994
      kevinf
        The 1942 (?) manual for the Ranger says 3/32 lift, 3oz with valve on seat and approximate float level with float chamber full from top of bowl to the gas level 23/32 if that helps.
        Kev
        #11997
          You didn’t say what year it is. This is for 1938. Make sure the exhaust ports are not caked with carbon. That can happen when idling in cold water.
          #12030
            • This reply was modified 5 years, 11 months ago by Tubs.
            #12044
              Great Post, Tubs. This is the sort of thing we should be saving on the tips page. It would also make a great article for the between the Outboarder publication News Letter.
              #12048
                quote Garry in Tampa:
                Second that! I made sure I saved this one!
                #12075
                mercuryman
                  Thanks, thats ever-ting I need to know on the Pal poppet carb.
                  #12085
                  LLOYD LAUTNER
                    Great post Tubs! Wish I could figure out how to save it.
