Home › Forum › Ask A Member › Poor Thing!
  • #5210
    ausob-collector
      I came across this horrible doing when browsing our Australian Gumtree.
      Anyone seen anything like it before?
      Cheers
      BP
        That’s the new aftermarket lightweight racing flywheel.
        #43663
        2fast4me
          I guess that’s one way or getting at the coils.
          Not the preferred method.
          2Fast4Me
          #43664
          Randy in Tampa
            looks like somebody cut apart and then broke off the flywheel so they could salvage the coils and points, I guess he didn’t have a flywheel puller 😯
            #43665
            vintin
              That’s a ‘knuckle slicer’.
              Just reach in and give it a firm twist.
              #43669
              kerry
                Am I seeing this wrong, or did he also "salvage" the carb, crankcase, pistons and rods? An awful lot of daylight showing in the first pic….
                #43671
                bullie
                  The gas cap looks to be in pretty good shape.
                  #43678
                  David Stanton
                    All is not lost! Cobble an old automotive generator wired to run like a motor to the top and you will have an electric trolling motor!
                      I have seen that happen when an auto mechanic used a gear puller (which hooks to the edges of the flywheel) to remove the flywheel in order to work on the magnito. The flywheel came off, but the flywheel hub didn’t! . . ., 😀
                      #43680
                      David Stanton
                        Like the one Garry saw, some years ago when I didn’t know any better, I cracked off a flywheel on a 1958 35 Johnson using an automotive brake drum puller. I knew a flywheel puller was the way to go but didn’t have a suitable one and wanted it off NOW!
