Home › Forum › Ask A Member › Polishing brass
  • #270443
    14decoys
      The Johnson LT 10 I’m working on has a brass lower tube. I’ve seen these polished and really like the look. Can someone recommend a method or product to accomplish it? And thanks for helping a newbie
      #270445
        I used Brasso on a Champion motor I restored.   Worked great.
        Polished-Driveshaft-Tube
        1982 Evinrude 25hp
        #270447
        14decoys
          Nice! Thank you, Ill give that a try
          #270448
          14decoys
            #270452
            todd281
              If you have a 4-1/2 inch angle grinder, buffing wheels are sold to fit it. a little green or white rouge and viola.
              #270455
              14decoys
                Thanks!!!
                #270457
                  I find Brasso the only polish the will cut through
                  the really tough tarnish like what you find on a
                  brass muffler. But once I get that off the grit in
                  Brasso leaves fine scratches. My first choice for
                  brass would be the Zephyr. This is the only metal
                  polish that I know of the dries to a haze that just
                  wipes off. The White Diamond is what I use the
                  most of as I can purchase it locally. I use the Blue
                  Magic as a final polish on aluminum as it seems
                  to reduce the swirl marks – sometimes. I’ve tried
                  all the metal polishes I aware of and anytime I
                  learn of one I’m not aware of I will give it a try.
                  #270458
                    a little sanding with wet 1000 grit sandpaper then polish works great for me.
