Home › Forum › Ask A Member › Polishing aluminum?
  • #49007
    nali
      I have noticed that the hardest part is removing the big defects.
      Once you have used 400 grit paper, sanding with 600 – 1000 – 1500 -2000 (and 2500 if you have it) is really a fast job.
      At this point, you can have a really clean result by buffing by hand with a polish paste for cars without the use of a wheel buffer.
      I once polished a part made of cast iron for a car. The first step with done with a Dewalt grinder. It’s been a lot of work until using paste 🙂
      #49226
      beast
        I found this post many years ago from a gentleman who polishes motorcycle frames for a living. It is very informative but also funny (don’t view if you are easily offended by profanity)
        https://forum.caswellplating.com/forum/metal-polishing-questions/1824-motorcycle-polishing-101-class-is-in-session
        #49227
        beast
          Here is another good thread on polishing
          http://caferacertv.com/tech-talk/aluminum-polishing-101/
