Home › Forum › Ask A Member › points pads
  • #285322
    DougConrad
      I’m attempting to rebuild my 1956 Evinrude 3 hp. I have a Sierra Tune-up Kit (18-5006). Everything looks pretty straight forward except I can’t figure out where the pads go.
      Any other tips would be appreciated.
      Thanks, Doug
      #285325
        The wiper felt goes in a clip that sits atop a post, underneath
        the coil laminates.
        DSCN4362
          it is all in the book !!  everything you need on oldies mid 40s and up to 60s
          carbs  magneto  GC  PH  timing etc…   400 + pages   just downloadand print locally
          https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
          #285339
          DougConrad
            Thanks for the replies. There are no clips on this motor. How necessary are the felt wipers? I suppose I could make some.
            I will order the manual.
            Thanks,
            Doug
            #285341
            Dale
              Thanks,
              Doug
              Doug, if this motor was mine I would put some grease on the rubbing block of the points and forget about any wipers.  Millions of automobiles on the highways use a little grease on the points rubbing block and it works fine.  As the block wears the grease keeps it lubed.  JMHO
              dale
              #285354
                well… the oiler pad oils tha cam  which reduces wear on the points rub block.
                the clip is worth crazy money last time I looked …  try to find a used one  they are all the same.   Somebody must have one in a parts bin… 🙂
                the felt can be cut from a sticky felt pads.. install with felt on cam  and  moisten with 2 drops of  oil I use gearcase oil
                #285357
                  As Dale suggest you want to put some grease
                  on the back side of the rubbing block of the points.
                  Automotive points would come with a little capsule
                  of grease to be placed in this location. As the points
                  ware grease is applied to the point cam, prolonging
                  the life of the points.
                  #285370
                    I always assumed the grease was for the pivot point itself… the  oiler pad  takes care of the the rub block but I guess with no oil pad… grease would help… for a while
                    #285386
                    T….in Wisconsin
                      Are you sure there’s no clip?
                      Have you already removed the coils, clip is tucked under a coil heal and not easily seen if the wiper is missing.
                      Here’s a pic of the clip and wiper removed, this may help.
                      #285493
                      T….in Wisconsin
                        Replaced all  Mag components on the 67 Ducktwin
                        Pic of felt wiper pad installed.
                        Wiper bracket is included with the new points kit.
