Home › Forum › Ask A Member › Points cam
  • #6901
      I just came across this service bulletin and thought I’d share it, since there is so much misunderstanding and misinformation out there. Especially concerning the cam on the right. Note that the keyway is at the extreme end of the allowable setting area. Knowing that, it might be better to set your points a tad before the keyway comes around.
      how to use print screencertificity.com
      #57008
      RICHARD A. WHITE
        So, I can’t imagine setting it near the end of that 46 degree area and having a good running engine. But man that info is invaluable.
        Thanks Frank
        classicomctools@gmail.com
        #57014
        PugetSoundBoater
          Good info and thanks for sharing Frank. Jim PSB
          Robbie Robertson
          #57015
            OK, the way I read this is that the "high point of the point cam" is only 10 degrees, a very narrow band, when compared to the conventional universal mag motors. At least you know exactly where on the cam to set the points on these low tension models. Needless to say, using the timing fixture avoids any guess work. Perhaps I am missing the point of the bulletin.
            I always rotate the crank a few revolutions after setting point gap (if not using the timing tool), while watching the points open/close, to ensure the gap is correct.
