Home › Forum › Ask A Member › Point gap 1940’s GoodYear Seabee
  • #276101
    Frank Cornine
      Just acquired a 1940’s?? Goodyear Seabee outboard. Data plate has been removed. Appears that someone painted the outboard with a brush. Was seized up. Freed up the piston. Has no spark. I’ve been slowly taking it down and got to the points. Somewhat corroded but got them cleaned up pretty good. I haven’t been able to find any information or specifications on this unit. Single cylinder, water cooler, and I’m thinking it might be a 3hp unit. Does anyone know what the point gap might be..??? Any help or direction would be greatly appreciated. I didn’t see anyone listed for GoodYear Outboards in the AOMCI directory.
      Thanks,
      Frank
      #276107
        Point gap would be 0.020″ on any of them.
        As for I.D. are the magnets in the flywheel or are they a round rotor in the center?  Does it have 360 degree steering?
        #276115
        Frank Cornine
          Magnets are in the round rotor in the center and not in the flywheel.  It does not have 360 degree steering. Has a caring handle attached to the stern bracket. I attached a picture.
          #276116
          Frank Cornine
            Frank Cornine
              Not sure where that picture came from. It’s not mine. I can’t get my picture sent to you. It’s a .jpg and only 1.4 mb
              #276118
                Try renaming your photo and see if it appears here.
                By the way, nice gaskets!
                #276123
                  Motor is a 1945-46 Model 0253555 (Gale model 135A)  OR an early 1947 model 1G1 (Gale model 1G1).  Motor was redesigned in 1947 with 360 degree steering.
                  Pg-10-Powerhead-and-Bracket
                  Pg-11-Lower-Unit
                  Pg-13-Trim-Group
                  Pg-12-Trim-Group
                  #276131
                  Frank Cornine
                    Frank, the illustration you sent is great. Looking at the trim my model appears to be the 1G1 version.
                    #276132
                    Frank Cornine
                      Frank, I have to figure out how to rename my files. I tried sending it several times
                      and get the same error. Another question. How do I remove the rotor assembly? Looks like
                      it utilizes the same key as the flywheel. Does it just pull straight up?
                      #276138
                        Yes, it just pulls straight up.  Perhaps a gentle pry from a couple of screwdrivers.  They did make a special tool to grab hold of it, but I never had one, nor needed one.
