Home › Forum › Ask A Member › PO-15 Carburetor
- This topic has 9 replies, 3 voices, and was last updated 10 years ago by
garry-in-michigan.
October 21, 2016 at 10:50 pm #5543
Putting the carb back together on my PO-15.
When I took the throttle butterfly off the shaft
for disassembly, the "flat" was facing down.
The parts manual would almost suggest it goes up.
Q. Which is correct?There’s quite a bit of slop in the throttle shaft bore.
Q. Would that affect operation on this type of carb?
The bottom shaft bore is a dead hole, but the upper
shaft bore goes to atmosphere.Thanks!
October 22, 2016 at 12:01 am #46270October 22, 2016 at 1:25 am #46276Thanks Mumbles, looks like I’m good to go!
Looks like your carb has a crack to fix.
Any thoughts on the sloppy throttle shaft bore?Prepare to be boarded!
October 22, 2016 at 5:19 pm #46312Air leaks around the shaft will usually affect the idle quality of a motor but since these motors are sucking in a fair amount of air anyway, it might not matter too much. Heck, hang on and run it full throttle!
October 22, 2016 at 5:25 pm #46314I silver soldered the worn areas of the throttle shaft.
That was the easy part….. then ground, machined
on the lathe, and filed them back to kind of original
size. I should have soldered the areas oversize instead
of just back to normal, but it is tighter than before!Prepare to be boarded!
October 22, 2016 at 6:05 pm #46322October 23, 2016 at 12:53 am #46335Mumbles, I thought about the "bushing" idea, but like you say, if the shaft is
worn bad, it’s not going to cure the slop.
Making the shaft "round" again with the silver solder helped, and
then I came up with the idea to put a "shaft seal" on the top side
so it can’t suck air around the shaft…… not saying it will work,
but not out much. One O-ring, a spring, and a washer!Prepare to be boarded!
October 23, 2016 at 3:50 am #46345
Thank you all – it’s the first time I’ve had a really good look at the Vacturi carburetor Johnson used on their POs. . . ๐
October 23, 2016 at 4:21 am #46347quote Garry in Tampa:
You must have been a Chevy type of guy and never had anything to do with Fords! ๐
October 23, 2016 at 2:15 pm #46365Because of Harry Johnson’s failure to honor a verbal agreement on a handshake with Dad, Johnson was a dirty word in our house. When offered employment By Ole Evinrude and Lou Johnson in 1928, Dad thought the Johnson brothers could not be trusted went with Ole at Elto in Experimental Engineering. In less than a year he was working at Evinrude with Irgie Irgins and Denny Watkins. . . ๐
