Home › Forum › Ask A Member › plug, Johnson MD 39
  • #887
    davidk
      Yup, another question. On my Johnson MD 39, I have the original plug, and a new plug. I put a new wire, boot, and new plug in, cause newer is always better right? But the new plug is too high to be able to raise up the rear cover. Are there shorter plugs available? I’ve seen a J6C suggested. And, it looks like I need to lose the boot.
      #11749
        You want a short lawn mower style with the same heat range. I don’t have the codes anymore for the NGK or Champion plugs but a small engine shop should be able to help you or try a Google search.
        #11761
          I believe the lawn mower/chainsaw plug is a CJ-8. But things change, so take a look at it.
          #11787
          LLOYD LAUTNER
            Why not use the old plug? Looks way better than the new one IMO.
            #11793
            davidk
              I need the old style clip that goes on the old plug. What’s that called? What’s a good source?
              #11796
              49hiawatha
                Check for plug fasteners on e-bay. I bought some brass/clip/circular hole,clip or solder plus brass thumbscrews. IHe was from MA and I believe it was something like the oldengine (?) seller name.
                #11826
                Phil Budne
                  Rajah clip. Check member Russ Larson’s Martin site I think he has them and the Rajah boots as well
                  http://www.omc-boats.org
                  #11827
                  DAN ANDERSON
                    I bought mine off EBay under Harley Davidson restoration. They have all styles in solid brass in all thread counts for NGK and Champion or others. Not sure what thread count for NGK is , but I bet Mumbles knows!
                    Dan in TN
                    #11829
                    cajuncook1
                      davidk
                        Thanks for the info and suggestions!
                        -DK
