Home › Forum › Ask A Member › placement of skid fin
- This topic has 6 replies, 6 voices, and was last updated 10 years, 6 months ago by
jw-in-dixie.
May 6, 2016 at 3:17 pm #4218
I have an 11′ Clarkcraft replica 50’s racing runabout. The problem with it is the tendency to skid (slide sideways) through turns. I have what I think to be a vintage aluminum skid fin made for this type of application. It measures 13" by 5". The boat is not a hydroplane and the skid fin is not the type used on a hydroplane. My question is, where along the keel line should this piece be installed? Should it be used at all? I’m thinking either the linear center or possibly the center of gravity. Suggestions from knowledgeable folks would be appreciated.
May 6, 2016 at 4:14 pm #36090Traditionally they were placed about 4′ fwd of the transom on the centre line. As racers began to raise their motors, some found turbulence from the fin cauised cavitation , so they moved it about a foot off centre to the left, as in NA we always turn left. Problem for cottage/river racers is the boat will not turn to the right very well , and turbulence will affect the prop in right turns.
For hobby use, and since u are not concerned with every last mph , I would attach one or two ‘skid rails’ , ie pieces of hardwood, maybe 2"x 2" or so, along the bottom that would help steering some and make it much easier to trailer and beach.
Your choice. PS; -that fin may be a bit big ?May 6, 2016 at 4:36 pm #36092Absolutely love that boat and motor combo. The Martin 200 is at the top of my "motors I must have before I die" list. I agree with bh, that fin is to large for the combo.
May 6, 2016 at 4:48 pm #36093I concur on the skid rail idea. Makes for easier launch and retrieval, too, as the fin has a nasty habit of snagging whatever you’re pulling the boat up on…
May 7, 2016 at 1:25 pm #36133Thanks for the input. I’ll try the wooden rail first. Looks less likely to cause major problems.
May 7, 2016 at 9:46 pm #36165May 7, 2016 at 10:29 pm #36167My 8′ runabout used to slide all over the lake until I put this 2" x 8" ski fin on it. Cured the problem.
Located for left turning, but will turn right at less speed.I think the fin you showed is from an old slalom ski, and too big. It doesn’t take much. Good luck. 😀
