Home › Forum › Ask A Member › Piston Rings
  • #269907
    geary
      Guys,     I’m in the process of restoring and Evinrude Fisherman serial no. 426900200 ! While pulling the cylinders to remove the pistons and rings I broke a couple of them ! I was trying to loosen them so I could get my ring expander tool on them to take them off but no such luck !  So my question is,  do any of you have new rings that will fit or can direct me to someone that I can purchase them from  ?  It’s a 2″ bore x .125 gap width and the rings don’t have locating pins, the end gaps have steps in them that overlap each other so when inserted into the bore the end gap almost disappears !  Any help would be greatly appreciated !
      Thanks and remember ~  Keep the blue Smoke Flowing !
      Gary
      #270217
      LeeRoy Wisner
        Here is a guy who makes obsolete piston rings at a reasonable price
        New piston rings — OTTO GAS ENGINE WORKS 2167 Blue Ball Rd Elkton Maryland 21921-3330
        phone: 410-398-7340
        E-mail address: otto@ringspacers.com
        Home Page on the web: http://www.ringspacers.com
        #270232
          I have ordered individual rings from this outfit before.
          They’re straight cut ends, but may be better than no rings
          if you can’t find the correct ones.
          https://www.dlastore.com/cylinders-pistons/individual-piston-rings/compression-piston-ring-51-x-3-17-mm-2-008-x-0-125-in.html
          LeeRoy Wisner
            He can made them either way, but you have to wait about 3 weeks as they would be custom made.
            #270243
            JOSEPH BRINCAT
              Gary, where are you located? any “old school” marine dealers in your neighborhood? maybe find some NOS rings.  Here in SE Michigan we have a couple possible sources…
              Lockemans 313-842-0268, Northwestern boat 248-808-2571, Carls Boats 586-7734545
              #270301
              sutterhome
                lots on ebay
