Home › Forum › Ask A Member › Piston ID Help Please
Viewing 11 post (of 11 total)
  • #61130
    kees
      International Member
      found an Archimedes outboard model with a bore of 54 mm
      that needs a piston with a diameter of 53,95 mm
      with a calculator help……that’s 2.124 and you need 2.121 !
      wrist pin is also not quite correct, but it depend how desperate you are
      and how handy
      the million dollar question is…..
      do I have an extra pair and what is the value ? 😮
      shipping from the Netherlands ??
      see if I can find them and what the other measurements are in inch.
      btw . I have a lot Penta outboard pistons with diameter 53,95 mm but all have two ports in the skirt
      that makes it for your model useless
