Home › Forum › Ask A Member › Picked up a Goodyear something or other….
Viewing 10 posts - 11 through 20 (of 25 total)
  • #59128
    huntleybill
      Hey wait Mumbles…mine does not have a twist throttle!! Could just be missing for all I know!
      8:1 ??? I did not know that. Thanks for letting me know. I usually have a 16:1 mix for any motor I start up no matter what HP it is. I have no idea how long these have been sitting so I run them heavy on oil. But 8:1 surprised me. I will do that.
      According to that parts diagram, I need part # 6,7,8,9, and 10!
      #59138
      johng
        Part 15 is the water pump. Don’t drill the prop. I think I have parts 15and 17 and 18 here in Ohio Stan 1-419-589-58one8
        #59143
        huntleybill
          I was kidding JohnG. I won’t drill the prop. The parts I need are 6,7,8,and 9. 🙂
          #59149
          jerry-ahrens
            I’ve got a couple of the Sea King version of that motor. They are pretty torquey, and make pretty good power.
            #59157
              I get 1948 for model 025-3565
              #59163
              melugin
                Several of the Michigan Wheel props for this motor were not drilled as the stock prop. They did not cover as much of the lower unit area.
                #59164
                  Many Gale built motors used the same basic motor. The Sea King was probably the most popular. The Elto Speedster came out in 1949. It was adapted to Johnson’s gearshift tower around 1951. Meanwhile Evinrude Souped it up with better reed valves and needle bearing rods for there 14 horse Fastwin. . . 😆
                  #59165
                    Is your Sea Bee 12 parts book the same as mine?
                    #59180
                    huntleybill
                      Ahhhh…so what your saying s I could make this Goodyear a Sea King Just by changing the paint and the decal!
                      Hmmmmmmmm!
                      #59182
                        Garry, I have that parts book too. But the picture I posted earlier was from a 12S10 (1951-53) because it is an exploded view.
                        Same motor really except the ’51-53 has the Universal Magneto.
