Home › Forum › Ask A Member › Petcock Thread Sealer
- This topic has 5 replies, 5 voices, and was last updated 8 months, 2 weeks ago by
Johnson RD.
February 23, 2026 at 11:51 am #304978
I’m reassembling my ’57 Lightwin and looking for recommendations on what type of thread sealant to use on the fuel tank petcock.
"Every time you remove a broken or seized bolt an angel gets his wings."February 23, 2026 at 12:24 pm #304981I usually just use some Permatex Aviation sealer and have no problem,
but sure they’re something better for the application. Maybe I’ll learn
something.Prepare to be boarded!
February 23, 2026 at 1:05 pm #304987I also thought about Permatex Aviation sealer. I had to replace an in-line fuel filter on my ETEC 150 last year and used Rectorseal No. 5 on those fittings and it seems to work fine. Just wanted to get some ideas on what other folks were using.
"Every time you remove a broken or seized bolt an angel gets his wings."February 23, 2026 at 1:41 pm #304988yellow teflon tape seems to work OK .
February 23, 2026 at 2:45 pm #304990I like the Permatex Aviation gasket goo!
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
February 24, 2026 at 7:35 pm #305010Indian Head gasket shellac
- Product Line: Indian Head Gasket Shellac
- Sealant: Yes
- Temperature Range Minimum (Fahrenheit): Minus 65 Degrees
- Temperature Range Maximum (Fahrenheit): 350 Degrees
- Fuel Resistant: Yes
