Home › Forum › Ask A Member › Parts Motor #1 What is it?
  • #2985
      Any ideas of Make, Model, Year?
      Thanks
        Mercury bloodlines in that one
        #27165
        jasonh
          Kd3 or kd3s…has spark plug cover and newer style mag mount
          #27193
            Jason, looks like you’re spot on with the KD3S
            naming. Looks like the same "bra" type spark
            plug cover on this one….
            http://store.oldmercs.com/category_s/86.htm
            green-thumbs
              Crankshaft does not shine. May mean it had "wet" storage..corroded stuck
              Value may be only in spark plug cover. Always nice to have a parts motor
              just in case.
              Louis
              #27227
                Found another Merc in the pile today.
                This one complete, but froze, it’s a
                1941 KB-3 Mercury Torpedo 3.2 hp.
                Similar block to the two parts motors.
                chinewalker
                  Might be able to make something from the two. At least from an external viewpoint, you now have a more or less complete motor between them.
                  #27248
                  green-thumbs
                    A good cleaning may be first order of business. After you can see what you have to work with
                    an orderly tear down may go easier. If my experience is any sort of guide…do not take apart more than one at a time. Focus on one until you get it back together! Do as I say not as I do advice.
                    Kiekhaefer reinvented the early K Models each model year. Some parts were carried thru from first to last while other evolved. Restoration to use may involve using what will
                    work while restoring to as it left the factory means a correct replacement for any needed
                    component.
                    Jason Baxter’s Wizard site is well worth time to review threads and pictures as the early
                    Kiekhaefers have much in common as well as a few differences. Each example of the Early K Model Kiekhaevers gives new lessons and knowledge.
                    USE your CAMERA to document before during and after. If you have a question a picture is
                    worth a 1,000 words and saves time.
                    Love the little mercs….they were good enough to start the company.
                    If you need a part I may have or be able to point you in right direction.
                    Louis
                    Id tag on Starboard side ..are all KB3 so tagged? Not consistent with the prewar models
                    in my accumulation. I "ASSUMED" prewar Port postwar Starboard. Live and Learn.
