Home › Forum › Ask A Member › Paper thin gaskets
- This topic has 19 replies, 10 voices, and was last updated 2 years ago by
Tubs.
September 21, 2024 at 9:23 am #290980
OK, pictures not loading. One more try here.
"Every time you remove a broken or seized bolt an angel gets his wings."September 21, 2024 at 6:04 pm #290990I gave up trying to post some photos last night.
October 1, 2024 at 8:56 pm #291257Thanks bob! Will check out the other places to purchase.
October 1, 2024 at 10:27 pm #291263I’d be a bit hesitant about using the thin gaskets without the baffle plate as it might cause conflict between the top of the driveshaft and the crankshaft. There isn’t much wiggle room in there when assembled.
I’ve cut base gaskets using gasket paper from my auto supply. It comes in bulk and various thicknesses. The stuff I’ve used might have been around 0.030″ thick or thicker. Can’t remember. As long as it’s close to original it will work.
October 2, 2024 at 11:11 am #291276I gave up trying to post some photos last night.
Looks like pics are working again.
October 7, 2024 at 11:53 am #291395I’ve been wondering if I could use “Form-A-Gasket” like Permatex #2 under a power head. Disadvantages?
1956 Johnson 15 Hp, FD-10
1957 Johnson 5.5 Hp, CD-14
1958 Johnson 5.5 Hp, CD-15October 15, 2024 at 8:42 am #291513I’d be a bit hesitant about using the thin gaskets without the baffle plate as it might cause conflict between the top of the driveshaft and the crankshaft. There isn’t much wiggle room in there when assembled.
Mumbles,
I took a close up of my CD-15 which happens to have the PH off. It looks like the gasket is closer to 1/16″, so that agrees with your estimate of 0.030″ or thicker. In my case, closer to 0.060″.
On your homemade gaskets, do you recall if you applied a gasket sealant? If so, what kind?
Thanks
1958 Johnson 5.5 Hp, CD-15October 15, 2024 at 12:45 pm #291521FWIW last spring I put the exhaust on a 1958 Evinrude together with two thin gaskets and the baffle plate, no sealer. Result was black goop from the exhaust leaking into the bottom tray of the powerhead. See photo. Looks like the thin gaskets were leaking. I will replace the gaskets and this time use E/J/ BRP part number 508235 sealant.
October 16, 2024 at 12:46 pm #291558In the picture I posted previously, I applied Permatex #3 Aviation gasket sealer to the powerhead base gaskets.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
October 16, 2024 at 9:12 pm #291579 -
