Home › Forum › Ask A Member › Pals and Scouts
  • #6252
    tom-c
      I’ve thought that a Scout is the same as a Pal with cowls added below the flywheel and tank. My question is……
      Are all the tanks the same? OR do some of the Scouts have the gas filler moved closer to the flywheel sort of like a Cub? Or do ALL the Scouts have the forward positioned gas filler?
      #52278
        The Scout was a one year motor that morphed into the Ranger – The pal was always a Pal. . . ๐Ÿ˜€
        #52298
          Both early Pals as well as the early Scouts had
          the filler placed at the front of the tank.
          #52300
          tom-c
            Thank you! The argument is ended!
            #52301
              You the winner or the looser?
              #52304
              tom-c
                Loser….. ๐Ÿ™
                #52309
                  From the motors I’ve seen that "look" to still be original
                  the forward gas cap was use on both motors passing
                  Serial# 1000 by maybe a few hundred. This not to
                  say that you wont find the later tanks on the early motors
                  or visa versa because parts do get moved around.
                  There were actually 3 variations in the Pal gas tank
                  in the 5 years of production.
                  #52314
                  Randy in Tampa
                    I have one I’m sure his original and one is an older restoration, judge for yourself, I see some differences ๐Ÿ˜‰
                      Randy,
                      What are the serial numbers
                      on both your motors?
                      #52334
                      Randy in Tampa
                        The original one is 4201-01253 and the restored one is 4201-01555 , the thumb screw on the original one is different than most I’ve seen maybe it’s been replaced along line? Not sure if it was original to the motor? ๐Ÿ˜‰
