Home › Forum › Ask A Member › Painting 1930’s Johnsons
  • #1395
    GARY
      Was everything painted silver but tanks and fly wheels?Was block and exhaust manifold painted with hi-temp paint or same as the rest?
      #15268
        I believe that is correct. If I am wrong I am confident I will quickly be corrected. This site is very educational.
        #15319
        hag
          You are hardly ever wrong Garry and if you are they are not right! 😀
          #15327
            What model motor are you working on? Some parts came painted or polished.
            There is a list showing what was what in the Old Iron Reference Library for club members only thanks to Doug Hudgel and Dick Gorz.
            http://www.aomci.org/members/library/re … /index.htm
            #15344
            GARY
              Working on KA38 and 1931 A50.Thanks for the library link.I’ll check it out.
              #15362
              Doug Wilson
                The A50s steel parts are painted aluminum parts are polished. Might try scrubbing the paint may be ok on a lot of it just hidden under years of crud, at least mine was mostly ok.
                Doug
                turned off?
                #15371
                GARY
                  Most of the paint on mine is okay too.The power head is mostly devoid of paint after cleaning so I was thinking of painting it.The info in the members library says "light machinery gray" is that what yours is?whats left on mine just lucked kind of silver.
