Home › Forum › Ask A Member › Paint stripping
- This topic has 19 replies, 12 voices, and was last updated 10 years, 8 months ago by
Mumbles.
February 12, 2016 at 11:32 pm #3628
What’s been your experience with commercial paint stripping. Anyone used any of the commercial processes that use chemical of "soft" media blasting to strip the factory paint on aluminum outboard parts? … and NOT damage the aluminum base metal.
February 12, 2016 at 11:35 pm #31842Soda blasting, while expensive is the cats pajamas on aluminum. Glass beads or plastic work well also. I have heard walnut shells are a good alternative as well.
February 12, 2016 at 11:51 pm #31844I use soda and glass, depending on what im blasting.
Im now experimenting with Lime though. With some mediums, if not properly cleaned afterwards, you may have issues with the paint falling off. Lime seems to limit this issue.
February 13, 2016 at 12:23 am #31851Just had an aluminum boat hull soda blasted below the waterline. Evidently the material hung in the spray rails and has corroded some as it dribbled out. Could only use a hose to rinse, as it is too cold to get the pressure washer out. Was a lot quicker than stripper, and had some corrosion issues to begin with.
February 13, 2016 at 1:25 am #31857I use walnut shells exclusively….never an issues, removes paint and does zero damage to the base metal. Does not do the greatest with steel but then again, it should not do that well with steel.
classicomctools@gmail.comFebruary 13, 2016 at 1:34 am #31858Chris,
Do you have a soda cabinet at home? If so, what brand and do you like it?February 13, 2016 at 3:13 am #31864Thanks for the info on the media pros and cons. Has anyone ever tried some kind of commercial chemical stripping, maybe like they use for furniture? Thinking about chemical strippers, some kind of solvent based chemical might be OK, however a strong caustic chemical would attack the aluminum. Any experience along these lines?
February 13, 2016 at 3:15 am #31865My cabinet has glass in it. I have a portable soda blaster I use outside for cowls and such. They are not expensive models, but seem to work fine. I have never used a real high end one, so don’t have anything really to compare it to.
Joe,
I have tried chemical as well. Much more work I find, and ends up costing more. Plus, the fumes off that stuff are not good for you.
February 13, 2016 at 1:26 pm #31875I never had much luck with the chemical strippers either. I’ve tried the orange/citrus strippers, Zip strip, automotive aircraft stripper. Of them all the automotive aircraft worked the best but the fumes are BAD. Blasting was much better then any of them. The paints and primers used in the old days are tough stuff. I’ve often wondered what kind of toxic pudding I’m really creating when mixing it with the harsh strippers 😯
February 13, 2016 at 2:31 pm #31881Oh yeah, me too on the "toxic pudding" Jeff. I bet it ain’t good. I have done most
of my stripping on old house paint on wood. With the lead and the chemicals to remove it, it’s got to rival a dr kevorkian cocktail! 😐 -
