Home › Forum › Ask A Member › Paint Resources
- This topic has 8 replies, 3 voices, and was last updated 3 years, 8 months ago by
Bob Wight.
March 8, 2023 at 1:26 pm #273575
I have a ’57 Johnson 10hp QD18. I believe the colors are 57 Holiday Bronze and 57 Cream. My question is where can you get the authentic colors to do the painting?
Thanks.
'57 Johnson QD18 10hp
'53 Sea King 3hpMarch 8, 2023 at 1:29 pm #273576North York Marine and Vintage Outboard Paint both have the original factory colors available. Both place offer high quality paint. Here’s my 1958 QD-19 done with NY Marine paint – they also have the original factory decal sets.
http://nymarine.ca/colours.html
https://vintageoutboardpaint.com/
"Every time you remove a broken or seized bolt an angel gets his wings."March 8, 2023 at 1:47 pm #273578Thanks! That is one great looking machine! Did you use a clear coat of some type on top of the decals?
'53 Sea King 3hpMarch 8, 2023 at 1:48 pm #273579Also- Did you use a primer, and if so what kind?
'53 Sea King 3hpMarch 8, 2023 at 1:55 pm #273580I bead blasted everything down to bare metal, then applied a self-etching primer followed by the color coats. I typically let the paint cure about a week before applying the decals. No clear coat over the color coats or decals.
"Every time you remove a broken or seized bolt an angel gets his wings."March 8, 2023 at 2:04 pm #273581Thank you for the advice. I hope my project looks half as good as yours. Again, a really beautiful machine!
'53 Sea King 3hpMarch 8, 2023 at 9:56 pm #273625Bobs- nice job on the paint. Did you use rattle can or spray gun?
March 9, 2023 at 12:01 am #273627I typically use rattle cans from Peter McDowell at NY Marine. Here’s a shot of a 1956 30hp I did with the his paint.
"Every time you remove a broken or seized bolt an angel gets his wings."March 9, 2023 at 12:02 am #273628OK, trying again with the picture.
"Every time you remove a broken or seized bolt an angel gets his wings." -
