Home › Forum › Ask A Member › Paint questions
  • #289910
    I looking for some paint recommendations for my 1946 Johnson SeaHorse. It is the mist green. I know I need to use an etching primer after cleaning and sanding. The other recomendation I read was to use a urethane clear because of the gas. I don’t mind mixing reducer, color, and hardener, and then the clear. Where can I get good quality paint. I really don’t want to try and color match. Thanks alot, I really enjoy looking around and reading up.
    1946 Johnson KD-15(in progress)
    #289924
      I’ve always used paint from North York Marine with great results.   Excellent quality paint materials and exact factory color matches
      http://nymarine.ca/
      1982 Evinrude 25hp
      #289926
      Thank you very much. That is what I was looking for. By the way, I like your signature about the broken bolt. Ain’t that the truth!  Has happened to me many a time.
