Home › Forum › Ask A Member › P/N for 25019 big twin gears (1955)
  • #8268
    johnyrude200
      My old parts books only have the forward/reverse/pinion gears listed as a set. Does anyone know if each gear has a P/N?
      I’m sitting on a large slew of NOS parts, but need the P/N’s to find them in my own stash!
      According to the Evinrude reference guide, these gearsets were only used in 1955 and 1956 models. Are other gearcases compatible with these two years?
      #65094
        For the 25/30hp 1951 to 1956
        Fwd Gear: 375759
        Reverse Gear: 302517
        Pinion Gear:375835
        Gear Set: 375861
        For the 1957 35hp
        Fwd Gear: 375759
        Pinion Gear: 308692
        Gear Set: 376996
        For the 1958 to about ’66 35/40 hp
        Fwd Gear: 377174
        Reverse Gear: 305293
        Pinion Gear:308692
        Gear Set: 378726
        Whole Gear Cases can be swapped as a whole in other situations, just not individual gears into a different set. As an example the 1957 35hp has the same forward and reverse gear, just a different pinion, so if you needed just the forward and reverse gear for you ’55 or ’56 25/30hp, you could salvage them from a ’57 case.
        This help?
        #65096
        johnyrude200
          yes, where did you get the P/N’s? My original parts books don’t list these individually.
          #65099
            Need anything else ? . . . 🙂
            #65100
            johnyrude200
              it might be because the one I have is a Johnson parts book. The evinrude ones seem to tease them out into more detail.
              #65113
              DAN ANDERSON
                Get yourself a Johnson Common Parts Reference Guide. I have several from a 1965 Evinrude (they call it something slightly different) to a 1978. You can use more than one as numbers change. Some old parts/price books help too so you can supercede numbers.
                The books cover all major common parts & assemblies. Great reference material for older motors by models.
                Dan
