Home › Forum › Ask A Member › P-50 ring in P-40
  • #4096
    Randy in Tampa
      Can I modify a P50 piston ring to work in a P40piston if I file the gap ? 2 11/16 on p40 2 3/4 on the P50 🙄
      #35182
      TOM GOEPFRICH
        No. Even a .020" over size P40 ring in a standard bore would not be a good fit after filing end gap. I might have a NOS P40 ring around here if you need it.
        Tom Goepfrich
        #35192
        Randy in Tampa
          Hi Tom, I may need more than 1, how many do you have to sell? 😐
          #35200
          jerry-ahrens
            Randy, still soaking the PR 40 powerhead. I haven’t had any luck getting it unstuck. Will give it another try over the weekend.
            #35215
            Randy in Tampa
              Thanks Jerry 😉
              quote Jerry Ahrens:
              #35219
                Randy, if you can find them, +0.010 oversize rings will work in a given bore size. 1/16" (0.0625) oversize is just too much.
                I have lots of rings here for different things which I’ll never use but nothing near what you need. Anyone building a Ford flathead V8? Lots of those from std. to +0.070. Free. Take them.
                TOM GOEPFRICH
                  Randy,
                  Just checked and found I have two 2 11/16 +.010 which should work in a standard bore after filing end gap especially if bore has a little wear.
                  Tom
                  #35244
                  mike-stroz
                    You really want to give away those rings Mumbles? I know someone who would probably want them.
                    #35427
                    Randy in Tampa
                      quote Mumbles:
                      Mumbles, we need to talk!
                      #35441
                        I think he meant a set, not the whole collection, lol
