Home › Forum › Ask A Member › Outboard motor manufacturer
- This topic has 10 replies, 5 voices, and was last updated 3 years, 12 months ago by
frankr.
November 8, 2022 at 3:32 pm #268799
I recently purchased this outboard from a small engine repair shop for $30. Someone painted over any decals and data plate (couldn’t locate any) so I could not determine any information about this unit. It is a single cylinder water cooled motor. The side covers were removed when I got it. If anyone can help me identify make, model and year, I’d be thrilled! I have attached several photos.
Thanks,
Frank
November 8, 2022 at 5:29 pm #268814One of the Gale variants. (1940’s)
This reply was modified 3 years, 12 months ago by
frankr.
November 8, 2022 at 5:50 pm #268816Thanks for the quick response. I’ll start researching into Gale outboards….
November 8, 2022 at 6:48 pm #268825Maybe a Gale-built Goodyear Sea-Bee.
Bob Wight.
November 8, 2022 at 7:31 pm #268827Thanks Bob, I’ll check into that.
November 8, 2022 at 9:01 pm #268832If there is remnants of original blue and yellow paint, that would point to a Sea Bee
November 8, 2022 at 9:26 pm #268834Joe, Someone did a really bad job of painting the entire motor blue and white with a brush and covered whatever original paint and decals were on it. At some point I will start stripping the paint off to see what remains underneath. The more pictures I see of older Sea Bee outboards I believe that’s what it is.
November 9, 2022 at 12:49 pm #268860Typically, the run -of -the mill homeowner paint is not nearly as durable as the factory stuff, Good chance that with the initial application of a chemical stripper, you will see the original paint.
November 9, 2022 at 1:25 pm #268861Which do you want it to be? Choices are Western Flyer, Hiawatha, Sea Bee, Sea King.
November 9, 2022 at 3:01 pm #268871+ Viking, Atlas, Brooklure , made in 1.5, 3, 5 and 12 hp.
I have all 7 white labelled 1.5 and the Evinrude version (weedless) a close relative, along with several 3 & 5 in various condition.
The serial # plate should be between the 2 transom clamps. The tank looks like it is for a Sea Bee.
I believe you have a 3 hp, but the cast iron jug looks like it’s from an Evinrude Sportsman (around ’47, ’48) . As far as I know Gale 3s have an all-aluminum crank case and jug… Maybe Frankr can straighten that out.
