Home › Forum › Ask A Member › Outboard Motor Corp.
Viewing 10 posts - 11 through 20 (of 26 total)
  • #288615
      That motor was produced for several years as an Evinrude and as Sea King. Does it have a tag like this? I need the number to correctly ID your motor. Tubs
      p
      #288646
      what part of the serial number is the model number?thanks
      #288647
      yes that looks like the tag on it and the first 3 numbers are 432 also someone told me it was an elto ace but it don’t look like the ones that are pictured. I checked the chart if I’m reading it right it is a 1933 2.2hp.
      #288648
        Your motor is a 1933 Sport Single, 2.2 hp. Model #- 432, the last 4 numbers being the sequence of production. Tubs
        #288650
        MHarrington
          Hi, I have the serial number rangers for Evinrude outboards from 1929-1960 in The Old Outboard Book by Peter Hunn, if you find the serial number the years for them according to the book are:
          1929   11,616-13,926
          1930   13,927-15,782
          1931   15,783-9,990
          1932   16,991-17889
          1933   20,000-20,930
          1934   20,931-22,534
          1935   22,535-25,096
          1936   25,097-29,174
          1937   29,175-33,434
          1938   33.435-39,155
          1939   39,156-43,565
          1940   43,566-47,252
          1941-1944 there was no outboards made by Evinrude according to the book.
          1945   47,253-48,748
          1946   48,749-55,511
          1947   55,156-68,210
          1948   68,211-80,312
          1949   80,313-95,877
          I don’t think it would go into the 1950s or later because they switched to a recoil starter around mid 1940s or so if I remember correctly.
          #288651
          does the shafts being made of brass mean it was made for salt water?
          #288652
            For the most part, motors from this time, with brass lower units, are considered salt water motors. Your motor looks to be in unusually nice original condition and many here would feel preserving the original decals would give it more historical value than replace them, if they are even available. Tubs
            #288657
            am I missing something   I have checked some other pictures, and I might be missing a magneto or coil did they make them without one or built into the top. I see the spark plug wire coming out of the top of the motor going to the plug. I do have compression I haven’t checked for spark yet. ThankSANY0011
            you
            #288659
              Coil, points, and condenser are under the flywheel.
              #288663
              is this motor hard to find I haven’t seen any for sale.
