Home › Forum › Ask A Member › Opposed Twin Water Circulation
- This topic has 18 replies, 7 voices, and was last updated 4 years, 6 months ago by
JOSEPH BRINCAT.
April 17, 2022 at 11:13 pm #258444
Looks pretty … good job
April 18, 2022 at 12:20 am #258451The “before” pic had me fooled – good to see you got it worked out. Going to be another good looking motor.
"Every time you remove a broken or seized bolt an angel gets his wings."April 18, 2022 at 6:07 pm #258497Speaking of siphoning, in my younger days trying to siphon gas, you know suck suck spit kinda thing! I could never get it going with both tanks the same height. Only had luck when one tank was higher than the other. On these old kickers both ends of the water inlet/outlet are the same height. That seals the air bubble in the power head. No water can flow until the air is moved out. Do you guys think there should be a small hole in the down hill tube. Once forward movement starts the water going up the tube the air can get out and the water goes over the hill and air pressure is relieved shouldn’t it work better. Maybe even leave the down hill tube open for a pee’er?
wadayathink
dale
April 18, 2022 at 6:19 pm #258498I don’t think a pee hole in the water outlet is beneficial in this system.
The pee hole might just suck air in, lessening the siphoning effect.
The water coming into the powerhead should push air out of the whole
system.
According to my wife, I’m wrong at least once a day, so other opinions
may be better!Prepare to be boarded!
April 18, 2022 at 6:49 pm #258501to me it is more like a push then pull system. scoop is being pushed by the movement of the motor forward and the exit is being pulled by prop thrust. not like a siphon.
This reply was modified 4 years, 6 months ago by
DAVID.
April 18, 2022 at 9:12 pm #258510Atmospheric pressure must come into play when siphoning effect is happening.
Is the pressure in “front” of the prop, where the water from the powerhead exits,
under less pressure than behind the prop?Prepare to be boarded!
April 19, 2022 at 10:40 am #258524
The propeller as well as the forward motion of the boat pushes
water up the intake tube. This same forward motion creates
suction as the water passes where the water exits. Gravity
also helps the waters exit the motor. To get the water circulating
you should immediately go to full throttle. Then you can slow
down if you choose, checking the cylinders to be sure water is
circulating. For this system to work properly, especially at slow
speed, there cant be any air leaks. The motor above, I posted a
picture of, cooled well at every speed.
April 19, 2022 at 11:36 am #258526Atmospheric pressure must come into play when siphoning effect is happening.
under less pressure than behind the prop?Good question Buc! It would sure be nice if a guy would know if the water system is working before it starts smoking. Where there is smoke there is heat! That is good for pancakes!
dale
get’em wet….don’t lit’em set!!
April 19, 2022 at 5:04 pm #258580Defiantly more “push” than “pull” I think. Also maybe a little help from the thermal action in the water jackets, hot water does tend to rise.
