Home › Forum › Ask A Member › Oops…My armature plate doesn’t fit.
- This topic has 8 replies, 6 voices, and was last updated 2 years, 10 months ago by
Dave.
January 4, 2024 at 1:31 pm #283664
I have been working on a 1957 Johnson QD18 10hp. I rebuilt the powerhead. As I tried to replace the armature plate that the coils are installed on, I found that it won’t fit easily over the end of the crankcase. I think I can get it to fit on the top of my powerhead but once on it certainly will not move or advance as the throttle is opened. I know that the plate should move freely.
This is my first time working on an outboard, first time rebuilding a powerhead. I think that there must be an issue with how I re-assembled the crankcase, and the two halves are not mated as they should be. Can anyone think of another reason the coil plate doesn’t fit easily
'57 Johnson QD18 10hp
'53 Sea King 3hpJanuary 4, 2024 at 2:14 pm #283667Well it looks like I jumped the gun. Both the plate opening and the crankcase shoulder, after a good cleaning and buffing are now fitting just fine…Whew!
'53 Sea King 3hpJanuary 4, 2024 at 3:52 pm #283668got a copy of the johnson bible aka RED BOOK to work on your oldy ?
https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
January 4, 2024 at 8:44 pm #283677One thing you need to check – it looks in your pictures you may have the lower retaining ring installed upside down. The flat side of the ring faces up with the beveled edge side of the ring facing down toward the crankcase.
"Every time you remove a broken or seized bolt an angel gets his wings."January 5, 2024 at 7:39 am #283684I shared a link to my google drive for anyone that may need a copy of the manual
https://drive.google.com/file/d/1ENXLxO2Z6p4oSkQmJYOsRszO4U8Sfvnj/view?usp=drive_link
January 5, 2024 at 8:52 am #283686One thing you need to check – it looks in your pictures you may have the lower retaining ring installed upside down. The flat side of the ring faces up with the beveled edge side of the ring facing down toward the crankcase.
Unfortunately, many of the parts manuals that I’ve seen mistakenly show the retaining ring upside down.
Improvise-Adapt-Overcome
January 5, 2024 at 7:21 pm #283703One thing you need to check – it looks in your pictures you may have the lower retaining ring installed upside down. The flat side of the ring faces up with the beveled edge side of the ring facing down toward the crankcase.
Indeed they do. I made a random search through a number of my OMC parts manuals and probably half of the diagrams show the ring upside down.
"Every time you remove a broken or seized bolt an angel gets his wings."January 7, 2024 at 2:07 pm #283754I found the same issue (the hard, water-in-the-gearcase way) on the gearcase to exhaust housing gasket on my TD20. Ugh!
John Gragg
RIverside, CAJust starting in the hobby, please be patient.
48 Sea King 5hp GG9014A. Sold
49 Sea King 5hp GG9014A
48 Johnson TD20. Sold
49 Johnson TD20. Sold
54 Johnson QD15. Sold
55 Johnson CD12. Sold
57 Johnson RJE-19M
57 Johnson RDE-19January 9, 2024 at 11:04 pm #283812Thanks,
I will check that and correct it if indeed I have it in upside down.
'53 Sea King 3hp -
