Home › Forum › Ask A Member › OMC vs HF flywheel puller
- This topic has 87 replies, 24 voices, and was last updated 10 years, 3 months ago by
johnyrude200.
July 25, 2016 at 1:11 am #4835
I just finished reading a couple of threads re: how great the OMC puller is for removing a flywheel that is as stubborn as the one is on my ’66 Ski Twin. Before I spend extra time and $ on an OMC puller, I’d like to know if anyone had better luck removing their flywheel using the OMC tool vs the one that Harbor Freight sells. I have been soaking the flywheel/crank interface with penetrating oil for several days while the puller bolt is under considerable pressure (administered by an impact gun) in addition to whacking the puller bolt a few times and heating the interface with a Bernzomatic until its hot to the touch.
Will the OMC puller really do any better?July 25, 2016 at 1:20 am #40864Well, I have it, and it definitely makes things easier. I especially like the built in handle, and the durability of it.
July 25, 2016 at 1:21 am #40865What you sometimes need on the big crank motors like the one you have, is leverage on the wrench you have on the center puller bolt. I had to put a long 4′ piece of fence pipe on my wrench I had on the center bolt once to get one to crack.
July 25, 2016 at 1:27 am #40866I used mine daily for over 20 years and occasionally for 30 more. I’ve never resorted to penetrating oil or heat. Or waited overnight or days. A guy working in the shop by the hour can’t be taking that long to get a dumb flywheel off.
Disclaimer: Well then there was the one where some idiot put locktite on the tapers. I think I had to cut that one off.
July 25, 2016 at 1:31 am #40867I wedged a piece of wood between the flywheel teeth and the lifting eye so it wouldn’t turn using a 3′ pipe on a breaker bar. I left it under considerable pressure for about 48 hrs now.
Man, I HOPE the last guy that installed it didn’t use Loc-Tite.July 25, 2016 at 1:34 am #40868I just bought one from Crowley Marine, but haven’t had a chance to test it out yet. I have a ’69 Ski twin flywheel that gave me fits getting it off with the harmonic balancer puller. Broke a few # 8 bolts before it finally popped. I bet the OMC pull set would’ve made short work of it.
I’ll try it out soon as I finish my house maintenance…probably sometime in the late fall 😡
July 25, 2016 at 2:00 am #40874I don’t have the OMC puller or the HF puller. If I were to buy a puller for OMC flywheels I would buy the OMC puller. It is a very well made and perfect functioning tool. I made mine out of 1/2" steel pate. I use the center bolt from abother purchased puller (since I had it and it saved me making one) and for the tough ones I use an impact wrench on the center bolt. Most of the time that’s not needed but that pops the stubborn ones right off. Thankfully I have not found one loctited on yet. 😮
My vote is for the OMC puller. I bet you won’t regret it.
-BenOldJohnnyRude on YouTube
July 25, 2016 at 2:11 am #40875Willie,
Even as a Hobbyist, your time is worth something!! And if by chance you break something using a marginal tool, there goes your savings.
I have the OMC puller, and it is a PLEASURE to use.If you buy one, you will not regret it.
July 25, 2016 at 2:15 am #40876I just used the omc puller on a 58 lark last week. They work great.on stubborn ones I put the load on the center bolt then pry the flywheel up with a heavy duty screw driver to lift the ply in the crank. Then give the center bolt a wack with a small sledge. then re tighten the center bolt. normally 2 or 3 times of this and it will pop free.
July 25, 2016 at 2:29 am #40877 -
