Home › Forum › Ask A Member › OMC universal flywheel puller truly universal?
- This topic has 20 replies, 12 voices, and was last updated 8 years, 7 months ago by
Mumbles.
April 11, 2018 at 3:24 pm #73816
I just read this thread, and ordered the puller with the link provided by retiredoz. I’ve been using a harbor freight harmonic balance puller for years, but this one looks like a much better choice.
Thanks,
JimApril 11, 2018 at 3:37 pm #73817quote Bsplit:I just read this thread, and ordered the puller with the link provided by retiredoz. I’ve been using a harbor freight harmonic balance puller for years, but this one looks like a much better choice.Thanks,
JimI have the same tool from HF too. This is making me wanna pull the trigger on the OMC Puller.
April 11, 2018 at 4:41 pm #73821April 11, 2018 at 4:57 pm #73825When i first started working on outboards ,i had a friend make me a puller like the one Mumbles showed to remove the flywheel off my 25 hp.
I do like the idea of the BRP puller not having the conical point on the center bolt that could enlarge the diameter of the crank threads.
I ordered the BRP puller today.
Looks like we had quite a bit of interest on this subject of pullers. 😀
Thanks, Jim PSB"Some people want to know how a watch works, others just want to know what time it is"
Robbie RobertsonApril 11, 2018 at 5:25 pm #73827mumbles, how much weight do you put on that hardware-store eye-bolt?
April 11, 2018 at 6:11 pm #73829First thing I thought FrankR! Course I am use to lifting V-6 Loopers & an occasional V-8. The lifting eye that screws into the factory puller is 3/4" X 16 TPI I think.
Nothing wrong with the rest of the plates! The key is the shoulder bolts & thick hardened washers.Dan in TN
April 11, 2018 at 6:47 pm #73830Here is some light reading….:
http://www.almabolt.com/pages/catalog/b … ensile.htm
I read that as a 1/4 -20 bolt, grade 2 can hold a proof load of 1750 lbs with a tensile strength of 2350 lbs.
That is not the same as the amount of twisting torque they can handle..
So how much weight can a 3/8-16 standard bolt hold while lifting?
classicomctools@gmail.comApril 12, 2018 at 9:16 am #73864So a 1/4-20 bolt could, in theory, pick up a V8 outboard. However, in the reality of a rough and tumble boat yard, it would only take one jounce of the fork lift or a little angle change of pull, to skew the results……and somebody gets hurt.
April 12, 2018 at 12:04 pm #73866Just sayin’ this in the interest of safety. Those bent eye bolts generally are not approved for lifting…period. There is a difference in the tensile strength of an ordinary bolt and the strength of a bent eye bolt. With the eye bolt, you are exerting a bending force (trying to straighten it out). Furthermore, it was already bent sharply where the shank meets the eye, and now you are trying to bend it in the opposite direction. We all know what happens when you bend a wire back and forth.
Again, just sayin’.
April 12, 2018 at 12:53 pm #73869Agreed Frank which is why they use such large bolts.. to ensure that the bolt won’t fail… This is one time to err on the side of caution is a good thing
classicomctools@gmail.com -
