Home › Forum › Ask A Member › OMC Throttle Control Link Slop
  • #6264
      The hole in my Fleetwin’s "brass" throttle control link is worn oblong.
      What would be a good method to make the hole sized as new?
      Silver solder and re-drill?
      I know the slop probably won’t make much difference, but
      I’d rather fix it if I can.
      Thanks for your thoughts!
        I filled one in with, what else, brazing rod once and drilled it out again to try and get rid of the slop in the throttle. Solder would be too soft.
        #52404
          Mumbles, I guess I’ve never tried brazing braze pieces…… for some
          reason I didn’t think it would work. Thanks!
            Here’s what I did done to fix the sloppy hole.
            I found a hunk of brass tubbing 1/4" ID x 5/16"
            OD.
            I drilled the oblong hole in the throttle control link
            to 5/16", installed my new bushing in said link.
            It fits like new again.
