Home › Forum › Ask A Member › OMC Pressure tanks fuel hose connector O-rings
- This topic has 10 replies, 6 voices, and was last updated 7 months ago by
JOSEPH BRINCAT.
February 25, 2026 at 6:06 pm #305029
I had some o-rings in an envelope, marked as 301824.
When I went to replace the originals in the fuel hose
connector, I noticed the ones I had in the envelope
had about .034 larger outside O.D.
I bought these several years ago. I wonder if whoever sold them
used Sierra o-rings, or perhaps the McMaster-Carr #107 that
is supposed to work.
Anyway, I used the new, larger O-rings, and hooked up the connector
to a motor, and it seem to work fine.
Anyone else run into this issue with “bigger” o-rings?I hadn’t changed any connector o-rings out for quite a few years, but
luckily found my bootleg fixture to take the guts apart.
Found out that a little heat from my bottle torch worked wonders.One finished, one to go
Just about getting tired of working on gas tanks, but I ran out
of virgin outboards to work on.Prepare to be boarded!
February 25, 2026 at 6:26 pm #305035February 25, 2026 at 9:26 pm #305038Dale, I have some #107 O-rings on order for the future,
and will be curious to see how they measure up to the others.Prepare to be boarded!
February 26, 2026 at 6:07 am #305039The 107 o-rings are “smaller” but still work, they just do not apply as much pressure to the pins as the original.
The cup that holds the ring, just imagine the original ring is four ounces in that cup, the #107 fills like 3 ounces and still works.Frank used them for one reason….cost
They fit, they perform by sealing things up.Cost of an original OMC ring: Currently $3.10
Cost of a bag of 100 pieces of the #107 o-ring from McMaster-Carr: $3That is why I include them with the tool.
Richard
classicomctools@gmail.com1 user thanked author for this post.
February 26, 2026 at 9:07 am #305041The other reason is that the 107’s are the exact same size as the original 301824’s.
February 26, 2026 at 9:17 am #305044Thanks for the replies. I’m now confident that the 107 o-rings
for future use will perform okay.
I’m still going to measure them against the OMC rings (supposedly)
that I just installed for curiosity.Prepare to be boarded!
February 26, 2026 at 9:33 am #305046Yeah I wondered the same thing Buc. That was one of the reasons Frank suggested using them, and the chart bears it out (which might have been originally posted by Garry). And if Frank said it, it was good enough for me. I’ve been using them for years since then and never had a problem.
April 2, 2026 at 8:57 pm #313672This is all good stuff. Just ordered the connector tool from Richard. I have 7 connectors to rebuild. I see Richard says he supplies a bag of o-rings with each tool. That will be awesome. I was wondering if I could find an equivalent o ring to do the repairs with.
joining the club was the best thing I could have done. The advice I get from this group has justified my membership fee 5 times over!
April 3, 2026 at 8:39 am #313751This is all good stuff. Just ordered the connector tool from Richard. I have 7 connectors to rebuild. I see Richard says he supplies a bag of o-rings with each tool. That will be awesome. I was wondering if I could find an equivalent o ring to do the repairs with.
Not a bag of o-rings…lol to clarify, I offer a pair, (2), of o-rings included with the purchase of each tool.
Regards
Richard
April 8, 2026 at 10:48 pm #314629Well it was a bag and it did have a pair of o-rings. Still more than I expected. Thank you.
